ColtCentaur opened this issue on May 06, 2000 ยท 5 posts
ColtCentaur posted Sat, 06 May 2000 at 10:59 AM
I bought the Zygote motion pack (the one with 10 fighting moves) and im having a problem. I turn off all my IK chains to start with then import it along the Z axis (the X axis bends by figure into knots) and the neck/head is lumping up. If I do Restore-->Figure--> Head and Neck then it goes back to the correct un-lumped mesh but I lose the 'pose'. Any ideas? -Colt
bonestructure posted Sat, 06 May 2000 at 11:50 AM
Try unclicking use limits
CDunbar posted Sat, 06 May 2000 at 12:58 PM
making sure that the body is selected and not something else
bonestructure posted Sat, 06 May 2000 at 1:09 PM
I find that if I leave use limits on, many of the poses I want to use just won't work. They throw the model all around. Unclicking it usually gets the pose in, but sometimes you have to check to see if bodyparts are intersecting with each other
ColtCentaur posted Sat, 06 May 2000 at 9:38 PM
I turned limits off....and still it doesn't help. Im using the p4 nude man and the p3 nude man with the patch update. However if I use it on the defualt man it works (minus the errors) so im totaly confused now.
