JDWohlever opened this issue on Feb 05, 2003 ยท 6 posts
JDWohlever posted Wed, 05 February 2003 at 2:18 AM
MightyPete posted Wed, 05 February 2003 at 3:23 AM
Check in the atmophere editor. make sure that the part. Auto decay sunlight color is off. Or on the sky tab there is another spot that can give you a weird pull the color toward pink then the fog tab is one more place that could be giving you that problem set thos to 0. Finally the last tab. Effects. Check the all other light spot and the sun spot. It probibly coming from color shift. Turn that off. The other place it could be coming from is lens flare. Turn all that off too. It's easy to find just look around and turn off everything that looks pink or red. It's bleeding in from the default settings and the amount of lights you got happeneng there.
gebe posted Wed, 05 February 2003 at 4:22 AM
If what MightyPete says doesn't work, go in the material editor, click the EFFECTS tab and push LUMINOUS to 30 or more %. Do this for all white materials you used. Guitta
YL posted Wed, 05 February 2003 at 5:34 AM
Strange, I never saw that with Vue2.1. You can also check in the material if there are red highlights, but I suppose it's not the case. Yves
JDWohlever posted Wed, 05 February 2003 at 1:11 PM
Well, I have checked the following: In the atomsphere, first of all there is no sun as I deleted it. There is 0 fog, 0 haze, sky color and all other colors are 100 white. No flare, no colorshift, no decay. On the radial lights I have no flare, just pure white light. Same effect. Adding the 30% lum setting only washed out some of the pink but where shadows darken the pink is still there. Im totally baffeled. If someone out there can use a radial light dome with soft shadows that does not have the "pink" effect, can u please send me the scene file so I can compare? Thanks
JDWohlever posted Wed, 05 February 2003 at 1:13 PM
And interesting update. The pink is coming from the radial lights. It seems the more lights youadd the pinker it gets. I started with 1 light and started adding one at a time. When I got to 20 lights I started noticing a shift in the colors toward blue.. As you add more the blue shifts toward red.. ??
