pokeydots opened this issue on Feb 07, 2003 ยท 8 posts
pokeydots posted Fri, 07 February 2003 at 6:25 PM
Does anyone remember what files we are suppose to remove before we install the update? I must have deleted the e male from daz, and I don't want to remove something I'm not suppose too! Thanks :)
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
2.80GHz, 4000MHz System Bus, 2MB L2 Cache + 6MB Shared L3 Cache
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
•ATI Radeon HD 4200 integrated graphics
System Ram: 8GB
Jcleaver posted Fri, 07 February 2003 at 6:27 PM
Here ya go: Before running the installer please delete the following folders from your Poser Runtime folder to insure only the correct files are on your computer. Depending on the date you bought the Male Pak, some of these folders may not be present on your computer. "MalePak" in Runtimelibraries!DAZVictoria 3 "!V3 MalePak Heads" in Runtimelibrariesface "!MAT V3 MalePak" "!V3 MalePak INJ" "!V3 MalePak REM" "!V3 MalePak CH INJ" and "!V3 MalePak CH REM" in RuntimelibrariesPose
pokeydots posted Fri, 07 February 2003 at 6:31 PM
Thanks JC :) That was a quick respose!
System Ram: 8GB
Crescent posted Fri, 07 February 2003 at 8:30 PM
Thanks for asking! I didn't even bother looking at the readme. (Some day I'll learn not to be such a spaz. Not today, obviously, but some day.)
Patricia posted Sat, 08 February 2003 at 1:33 AM
Odd thing when I was doing that same deleting chore earlier today---there were no V3Male files in the Face Library at all...? Even did a search of the HD to see if they went somewhere else, but none showed up...?
rbtwhiz posted Sat, 08 February 2003 at 4:21 AM
Patricia, "Depending on the date you bought the Male Pak, some of these folders may not be present on your computer." As quoted, some folders/files may not exist on your machine. Most were created by the original installer. The folder/files in the face library were created by an update (which is no longer applicable). The new installer Ryan has been contacting everyone who purchased the MalePak about, is a replacement for the original installer... The original one is safe to delete along with the files it created once you have downloaded the replacement. -Rob
Patricia posted Sat, 08 February 2003 at 1:33 PM
Another mystery solved! Thank you :)
PheonixRising posted Fri, 02 May 2003 at 12:29 AM
These are the updated files: "DC_30_.............." ------------------------------------------- These are the out of date file: "PCBDC_30_.............." ------------------------------------------- DC=DefinatelyCurrent PCDBC=PreviousCopyDownloadBetterCopy above is just slang not real abbreviations.
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
