Forum: Animation
Subject: Latest Animation
zorger opened this issue on May 08, 2000 ยท 6 posts
zorger posted Mon, 08 May 2000 at 3:55 PM
Attached Link: http://www.vidivox.com/showpages/s18zorger.htm
here's a link to my latest animation. It was made with Poser and Flash http://www.vidivox.com/showpages/s18zorger.htm
lonebannana posted Thu, 11 May 2000 at 4:24 PM
rather good, rather good. I am also trying some work with poser and flash. I would like to know how you did that, if you don't mind. looks like a convert bitmap, is it?
fur posted Thu, 11 May 2000 at 4:30 PM
wow, you must have put quite a bit of work into that!! have any more?
zorger posted Fri, 12 May 2000 at 8:15 AM
I think it took me about 20 - 25 hours. Here's the process: First come up with some story to animate and track down the charcaters and props needed. Play around with the settings in Poser and Flash until the Flash image looks the way you like. For this piece in Poser set Display > Element Style to cartoon (no lines). I also set the window size pretty big, about 500 x 500. Usually its better to render each character and prop seperately and add them together in Flash. Render > anti alias the document, then edit > copy picture. Open Flash and edit > paste. Select the image and Modify > Trace Bit Map. Delete the background. Some times I then hop back into Poser and zoom in on the face from the same camera angle. Then I paste the the close up on top of the body, since the detail on the body is not as important as the face. The whole thing isn't really that hard and it's a lot easier then drawing and scanning to make cartoons. If any one makes something this way I'd really like to check it out so post a link here or e-mail me. Here are URLs of my Flash cartoons. Some of it was not made with Poser. http://www.vidivox.com/showpages/s18zorger.htm http://www.vidivox.com/showpages/s15zorger.htm http://www.vidivox.com/showpages/s14zorger.htm http://www.vidivox.com/showpages/s3.htm http://www.vidivox.com/showpages/s4.htm http://www.vidivox.com/showpages/s5.htm http://www.vidivox.com/showpages/s2.htm http://www.vidivox.com/showpages/s1.htm
ARADTech posted Sat, 13 May 2000 at 10:07 PM
Heheh, funny and good work :-) Chris
Lorraine posted Sun, 14 May 2000 at 1:55 PM
very cool, now I want flash more than ever.
