Forum: Carrara
Subject: Removing Fur [or any other modifier] from a model...
kelley opened this issue on Feb 11, 2003 ยท 4 posts
kelley posted Tue, 11 February 2003 at 12:00 PM
This is a first 'rough-cut' at my premier character: Conicja. Her hair, and tail, are nearly OK. Good enough to be goin' on with. But the fur on the legs is just too shaggy. [That and the increased render time.] I found a bump map that will work and now I want to delete the Anything Grows modifier. Clicking the 'minus' in the header of the Modifiers Tray is supposed to delete. But it's not working. Am I missing something? Is there another way?
litst posted Tue, 11 February 2003 at 1:29 PM
You have to select the deformer by clicking left of the little white arrow . Then, click the minus sign to remove it .
kelley posted Wed, 12 February 2003 at 12:29 AM
Thanks, litst. It worked. Previously, I was clicking ON the arrow, or the white dot above.
litst posted Wed, 12 February 2003 at 11:53 AM
A bit tricky, ain't it ? ;) Glad i could help !
