Subject: boots over pant leg help...
pbguy1211 opened this issue on Feb 12, 2003 ยท 6 posts
pbguy1211 posted Wed, 12 February 2003 at 12:26 PM
is there a certain way to get boots to fit over pants? or do i need to just change the length of the pants i want if i want the boots to be over them? thanks!
lelionx posted Wed, 12 February 2003 at 1:17 PM
if there is a taper morph on the shin of the pants that might work or making the shin invisable.usually i have to make some kind of morph for the pants to get them to look right.
vilters posted Wed, 12 February 2003 at 1:21 PM
You can put a magnet over the end of the pants to shrink them into the boots. Tony
pbguy1211 posted Wed, 12 February 2003 at 2:40 PM
tapering wasnt working the way would have liked it to, thanks for the magnet advise!
Tomsde posted Wed, 12 February 2003 at 3:15 PM
You can also create a new group on the shin that's covered by the boot and make it invisible. I did that for one of my characters and it seemed to work well, you also get a fuller leg sticking out of the boot.
pdxjims posted Wed, 12 February 2003 at 4:09 PM
It also depends on the pants you're using. Some legs taper differently than others (from the top and not the bottom). There's also some pants that have a fit-to-boot option to them. I use Tailor for this too. I morph the pants to fit a heavy leg, then use the new heavy morph in the pant to fit the pants leg over the boot. It works about 60% of the time.
