Subject: Propack reboots Windows XP
weip opened this issue on Feb 14, 2003 ยท 6 posts
weip posted Fri, 14 February 2003 at 7:58 AM
I just downloaded and installed Poser Pro Pack. When I now start Poser, I get to the screen where I can enter my serial number and personal information. When I want to continue, Win XP simply reboots. Using WinXP (german), Athlon 1.8 Ghz with 1 GB RAM. Any help how to fix this would be appreciated:) Phil
pink999 posted Fri, 14 February 2003 at 9:16 AM
Well, from what i saw, propack download is only enabled for the US (enlish version) and i see you have a german XP (german poser as well maybe?)
weip posted Fri, 14 February 2003 at 10:10 AM
Nope, I got the english version of poser. And even if there is a language issue, I don't think, rebooting the system is the correct action, is it?
RHaseltine posted Fri, 14 February 2003 at 12:45 PM
Unannounced reboot in XP sounds more like a driver issue, probably video. Does anyone know if the ProPack registration screen try being pretty?
Norbert posted Fri, 14 February 2003 at 6:05 PM
There's a setting in XP that'll make it automatically reboot your computer when there's a critical error. If you turn it off you'll get an error screen instead. The info on that screen is your best bet of finding out what's causing the problem. In Win 2000 the setting is in the "System Properties" panel "Adavnced" tab, "Startup and recovery". Maybe it's the same in XP. (?)
weip posted Sat, 15 February 2003 at 12:55 AM
Thanks Norbert, I'll give this a try. Could it be that Pro Pack doesn't like I'm using 2 Monitors? Poser 4 never had a problem with this, but who knows...
