Benettor opened this issue on Feb 15, 2003 ยท 9 posts
Benettor posted Sat, 15 February 2003 at 1:13 PM
PapaBlueMarlin posted Sat, 15 February 2003 at 1:27 PM
what file format did you export it as? an obj or 3ds?
SamTherapy posted Sat, 15 February 2003 at 1:46 PM
Sounds like the polygon smoothing thang which Poser does so well. You need to split the vertices (if my failing ol' brain is correct) then you'll have nice sharp edges. The good doctor (Dr Geep) has a tute all about dis kinda t'ing. Search for "geep" in this very forum. For the life of me, I cannae remember which of his tutes it is, and I assure you I have just been looking.
chanson posted Sat, 15 February 2003 at 1:53 PM
The above Geep tutorial is good. Two ways I know of to do this. the easiest is to take your obj file into uvmapper and do a "split vertices" on it there. The other is more complicated, but if you slightly chamfer your edges in 3dsmax, you should accomplish the same thing. I usually approach it with uvmapper, myself.
Valandar posted Sat, 15 February 2003 at 2:20 PM
If this is Poser 5, turn "Polygon Smoothing" off in the Render Options window.
Remember, kids! Napalm is Nature's Toothpaste!
Benettor posted Sat, 15 February 2003 at 3:27 PM
odeathoflife posted Sat, 15 February 2003 at 5:22 PM
Don't cross post, I answered your questions in the other forum and I see now it was a waste of my time.
♠Ω Poser eZine
Ω♠
♠Ω Poser Free Stuff
Ω♠
♠Ω My Homepage Ω♠
www.3rddimensiongraphics.net
Maz posted Sun, 16 February 2003 at 4:15 PM
Ditto Maz
Phantast posted Mon, 17 February 2003 at 5:09 AM
You also have a problem with your keyboard. Some keys seem to stickkkkkkkkkkkkkkkkkkkkkkkkk
