cat9 opened this issue on May 10, 2000 ยท 6 posts
cat9 posted Wed, 10 May 2000 at 9:23 PM
Hi, in Infini-D it is possible to use environmental maps to simulate reflections in reflective surfaces. (So if you make a chrome sphere you dont have to actually put real objects around it for it to reflect them.) Is it possible to do this in Carrara??? Thanks
Tuck3D posted Wed, 10 May 2000 at 9:49 PM
I believe you can add the enviromantal map to the reflection channel of the shader and you will get that same affect. Not sure though haven't really tried it.
ewinemiller posted Wed, 10 May 2000 at 10:24 PM
In the reflection channel, it will just control how reflective the object is, not look like it is reflecting. Try mixing it with your base color in the color channel. Here's a sample Good Luck, Eric Winemiller Digital Carvers Guild Freeware and commercial 3D extensions http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave
plug-ins
rudolf posted Thu, 11 May 2000 at 2:27 AM
just add the enviromantal map to the background tab in scene effects..../Rudolf
ewinemiller posted Thu, 11 May 2000 at 7:03 AM
That's the best way if you want a global environment map. If you want a different map on each object, Carrara doesn't really support it. You have to fake it or do different renders and put it together in post production. Eric Winemiller Digital Carvers Guild Freeware and commercial 3D extensions http://digitalcarversguild.com
Eric Winemiller
plug-ins
cat9 posted Thu, 11 May 2000 at 9:44 AM
Great!!! Thanks for all the help. I think that some of the better features of Infini-d were lost with its integration with Ray Dream. I think it was way easier to add colours and textures in Infini-d. But that's just my opinion (since Ifini-d was my first 3D application. I will of course try all your suggestions. thnx again, c9
