Forum: Bryce
Subject: 3dText
kravitz4 opened this issue on Feb 17, 2003 ยท 12 posts
kravitz4 posted Mon, 17 February 2003 at 5:22 AM
Hi everyone..I've been using Elefont for my 3dText in Bryce for the past year or so...all of a sudden it does'nt work anymore,cannot remove it to reinstall it. So while waiting for my next formatting i was wondering if anyone would know an easy free program like elefont that would do the job... Just 3d text i can import into Bryce as dxf,obj....Tanx
FWTempest posted Mon, 17 February 2003 at 5:41 AM
I think I'm the only one, but I still prefer to to create my text in white on black using photoshop, or any other image editing program. (I usually make it 512x512) In Bryce, create a terrain (or lattice), go into the terrain editor, increase the resolution to at least 1024 and import the text image. Smooth a bit, adjust height accordingly, mix well, and serve while hot. PS.. if you use the clipping bracket to adjust height, then make sure that the terrain/lattice is set to 'solid', otherwise it will appear hollow... which can be an interesting effect at times.
FWTempest posted Mon, 17 February 2003 at 5:45 AM
also, if you have RayDream or Carrara, you can create text in those programs and export in most formats. I'm guessing you don't have them, though, otherwise you wouldn't be asking.... nevermind... I need to get some sleep ;)
pauljs75 posted Mon, 17 February 2003 at 6:01 AM
The terrain method is a good quick way to do things. And would be considered the hardcore Brycer's way... But it results in a high density mesh. However if you like using a nice clean relatively low poly mesh... Both of the handy-dandy freeware modeling programs that I like (Anim8or, Wings 3D) produce mesh text in multiple fonts. Dunno if that helps any. If you need to know more about them, I suppose you could ask at the modeling or Wings3D forums here at Renderosity. L8R!
Barbequed Pixels?
SAMS3D posted Mon, 17 February 2003 at 7:08 AM
Why can't you remove it for reinstall? Sharen
kravitz4 posted Mon, 17 February 2003 at 10:42 AM
Great..i got a couple of solution to play with As for why i can't remove it Sharen..i dont have a clue ,it seems there is always something left because when i reinstall it ,it remembers the last word i worked with That's why i'm pretty sure i did not get rid of it completely and cant find the remains of that software..hum! it is a great any easy software to use ..when it works Tanx for the tips
pakled posted Mon, 17 February 2003 at 1:17 PM
If you're in a Windows OS- go to Control Panel, Add/Remove Programs, and go to the Install/Uninstall (depending on the OS) tab. Select 'Elefont', and click on the button below, Add/Remove. This should uninstall it. Failing that, go to the Elefont Directory, and look for an uninstall.exe, or something like that. Run that. Failing that, you could go into the Registry, and delete all the 'elefont' keys, but unless you're familiar enough with the Registry Editor, I would consider it only as a last step.
In any of the above, once you get the uninstall to work, you should be able to copy out your data files, delete the remaining files, delete the elefont directory, and be able to reinstall. Hope this helps.
Zanny posted Mon, 17 February 2003 at 1:49 PM
i agree with pauljs get anim8or (www.anim8or.com) and wings3d (www.wings3d.com)! Just for the text anim8or is the way to go, just type it change it to whatever font/size/style u want, extrude it and then save as a .3ds or whatever :) Takes me all of 30 secs :)
kravitz4 posted Mon, 17 February 2003 at 2:44 PM
tanx i got myself a copy of anim8or...cant wait to try it And pakled i did all of the above execpt ,play in the registry editor(since i dont know how)so i guess i'll take the easy way out and use anim8or thanks again for your fast response and BIG help
AgentSmith posted Tue, 18 February 2003 at 4:39 AM
Attached Link: http://www.armanisoft.ch/
Elefont doesn't install, or unistall. It is a single .exe file that just brings up the program when you execute it, that's it. Try going directly to the "EleFont.exe" (342kb) file on your hard drive and double-clicking it. If that doesn't work, try downloading it again, and trying that. AgentSmith
kravitz4 posted Tue, 18 February 2003 at 5:21 AM
Ok everything is in order...got an e-mail from the Man at Armanisoft(Armin),The only way to remove it was like Pakled suggested The SCARY Register move.Took my courage with both hands and went right in the belly of Windows Registry I am happy to annouce ,i have finally removed it So i can now reinstall it ...much smarter then i was Tanx to all .Dont i feel safe with all of You's out there guidding my every moves.tanx again
pakled posted Tue, 18 February 2003 at 11:24 AM
there's no real 'secret' to the Registry, except that if you get happy and delete the wrong keys or values, you can really screw up your OS. Usually all I do is pull up 'regedit' or 'regedt32', and do a search for the key name of 'elefont', for example. Usually there's not more than a couple (unless it's AOL IM, but that's another BC headache..;). I only caution that you ordinarily don't have to do this (that's a large part of what uninstall programs are for), but not everyone includes one. If you must try it, try to find someone familiar with it until you're comfortable.
