Subject: Poser 5 Help please
ladynimue opened this issue on Feb 19, 2003 ยท 7 posts
ladynimue posted Wed, 19 February 2003 at 11:01 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12419&Form.ShowMessage=1109261&Reply=1109938#3
HI everyone.. I need your help please for a Poser 5 and Print realated question that was asked in the Print Forum (see link above). The member wants to know about Rendering in Poser 5 and how to set the Render Settings. He wants his final output to be 8 1/2 by 11 inches and preferable to be 300dpi (for printing). Thanks for your help :) ladynimue
amon_g posted Wed, 19 February 2003 at 11:16 AM
I would try a width of 2550px by 3300px at 300dpi and see if that does the trick. Hopefully this helps. I'll also post this in the print forum. ~ brent ~
ladynimue posted Wed, 19 February 2003 at 11:23 AM
Thanks brent... I am not sure if he needed the pixel info or the instructions on how to resize the Render Window in Poser 5. I appreciate your help :) ladynimue
MaterialForge posted Thu, 20 February 2003 at 1:10 PM
I wouldn't resize the main render window - follow Brent's suggestion for resolution, but put those settings in the "Render to New Window" option in the Render setup, and check that option.
ladynimue posted Thu, 20 February 2003 at 2:09 PM
Thanks silver... :)
amon_g posted Thu, 20 February 2003 at 2:17 PM
Well, the reson I recommended resizing the main render window was so that you could get an accurate preview of the final output. I normally have my main render window set at 1024x1024 and then I'll kick off a render in a new window at, let's say, 800x600, well what typically happens to me is that the top/bottom of the image usually gets cropped simply because the final output doesn't match the main render window. The 638x826 I recommended for the main render window is a quarter of the final output. Again, this is something that I do just to help me out with the composition.
amon_g posted Thu, 20 February 2003 at 2:18 PM
Boy o' boy I wish this had a spell check:) reson = reason ~ brent ~
