Subject: Anyone had this Mover problem?
Maz opened this issue on Feb 21, 2003 ยท 1 posts
Maz posted Fri, 21 February 2003 at 6:10 PM
A Mover user contacted me today regarding a problem, as follows: "I am having a strange problem with your Mover 1.01 I am trying to decode some pcf-files for the Mike bodysuit (from DAZ Mike Clothink Pack 2) and all I am getting is a 'Range Check Error' :-(( There is another remapped version for this bodysuit, which is uvs-coded ...... no problem to decode with UVMapper. And there is NO update at DAZ for this bodysuit. So I seem to have the correct version of the object. I have tested a lot of other pcf-files .... all of them have no problem with de-coding. I have already searched the forum for similar problems. I ended with a posting where you said: 'It's probably caused because the computer doing the decoding is set up to use a comma (,) as its decimal separator rather than a full stop or period (.)' Tested both, the comma and the point - always the same error message. The files are no longer in the freestuff, so I can not contact the authors." Has anybody else had this problem or can the originators of the files shed any light on it? Unfortunately I don't have any of these files so can't even begin to investigate the problem. Maz
