Subject: Weird gradient when I render
ssgurl opened this issue on Feb 23, 2003 ยท 6 posts
ssgurl posted Sun, 23 February 2003 at 5:31 AM
Attached Link: http://ssgurl.d9games.com/gradswatch.jpg
I've never had this problem before but when I render in Poser 4 I get a weird gradient over large area with slight color changes (skin, shadows, etc.). I would say I have a decent understanding of Poser and like I said I've never had this problem before. But I'm just not sure what I'm doing wrong. My render resolution is set at 300 dpi and I'm starting with a high res skin. I saved the rendered file as a PSD file as well.
Please Please
Any help would be great!
There should be a swatch at the top of this post showing a part of the render.
Thank you =)
SamTherapy posted Sun, 23 February 2003 at 10:31 AM
This may be asking the obvious, but how big is your shadow map?
SamTherapy posted Sun, 23 February 2003 at 10:34 AM
PS. The swatch is too indefinite to get an idea of what you mean. It looks like an amorphous pink cloud.
ssgurl posted Sun, 23 February 2003 at 12:24 PM
shadow map? (not wanting to sound stupid, lol).
i have cut a bigger swatch out, hope this one is easier to see
SamTherapy posted Sun, 23 February 2003 at 1:53 PM
Thanks for that, but all I can see is that you have a seam issue on the texture applied to the human figure in your pic. In other words, the texture doesn't quite match up where it joins. As for a shadow map, each of the lights in your scene casts a shadow (or not, if you have turned shadows off) and it will calculate the sharpness of that shadow based on the size allocated to it (the "Shadow Map"). For a good, sharp shadow, you should be looking at a value of 1024 at least. If you select a light, one of the parameter dials will show "Shadow Map". This will tell you its current value; if it's below 1024, adjust upwards. If it's above... well, I dunno.
ssgurl posted Sun, 23 February 2003 at 2:51 PM
alrighty i've figured it out, it wasn't the lights but thank you for the suggestion. i'll remember to keep my eye on that from now on. the "seam" isn't really a seam it's part of the backgound. the swatch is from my PSD after I had started to apply postwork to other area of the image. thanks for helping!
