JBroneske opened this issue on Feb 23, 2003 ยท 9 posts
JBroneske posted Sun, 23 February 2003 at 9:48 PM
Has anyone ever received this error message on starting Poser? "Error - Requested window size too large, creating next best thing" And then I get no workspace square. All dials and everthing else is there, and if I load a figure and hit render, it renders - I just can't see the figure in the workspace area. It just started doing it and the only thing I have done different is to start using PBoost. Anybody have any idea why it's doing that and what to do about it? Thanks, Joan
classic posted Sun, 23 February 2003 at 10:13 PM
I ran across the same error about a week ago, but can't remember exactly how I got rid of it. I think the problem had to do with Poser not remembering my interface settings, so when a large work area was requested there was no clear space to put it. Try lauching Poser directly by clicking on the "Poser.exe" file in your Poser 4 folder. If you don't see the error message, then it's a good bet that the shortcut that Curious Labs put in your Start Menu Group is faulty. (I'm assuming you are using a PC). To fix just deleat this shortcut, and put a one that you made in there.
If that does not work try going back to the "factory presets" to get your work area back.
LarryT posted Mon, 24 February 2003 at 1:21 AM
When I had that error, I had loaded a pz3 file that used a huge render window. Now don't ask me why it gave the error, it just did. Once Poser was up again, and I closed out, reopened Poser, all was fine. Worst case scenario, recreate your settings (Doc Window size etc) and resave your new settings through preferences.
TygerCub posted Mon, 24 February 2003 at 5:52 AM
I had this problem mysteriously pop up a month ago. I didn't load anything new, didn't install any new programs, and my system was exactly the same the day before as it was when I opened it that day. One day, Poser just woke up cranky and decided it didn't want to play. The only way I found to fix it was to reset my "preferences" back to factory state. After re-opening Poser, I re-arranged everything to my satisfaction, and it worked just fine. I think it's Poser's version of a "bad hair day".
Cage posted Mon, 24 February 2003 at 9:18 AM
I have had my window disappear like that. Scared the bejeepers out of me. Do what TygerCub says, then set one of your UI Dots as a "rescue" dot, in case this happens again. And I always thought those UI Dots were just an annoyance....
Cage can be an opinionated jerk who posts without thinking. He apologizes for this. He's honestly not trying to be a turkeyhead.
Cage had some freebies, compatible with Poser 11 and below. His Python scripts were saved at archive.org, along with the rest of the Morphography site, where they were hosted.
JBroneske posted Tue, 25 February 2003 at 12:42 AM
Well, thanks everyone, but I ended up reinstalling. What I think happened was when I was moving files around with PBoost, I think I may have deleted some default something or other and messed up Poser. Anyway, I reinstalled and everything is okay now.
LarryT posted Tue, 25 February 2003 at 4:29 AM
Arrrrrrrrgh! Kids! (I too am a newbie, BUT......) It would have been much easier just to re-set your preferred state. Of course he may not have the10 - 12 gig runtime folders that a lot of us have. I have seen posts where users have 20 gig runtime folders! Wanna reinstall that dude! ;-) Just giving ya a hard time JBroneske. No offense intended, OK?
JBroneske posted Tue, 25 February 2003 at 11:59 AM
Well, I had a lot of folders, but not that many! I tried resetting my prefered state, but it didn't work, so that's why I think I must have moved something important that messed it up. :-)
LarryT posted Tue, 25 February 2003 at 2:07 PM
Sometimes the easiest way to do something is actually the most severe way! ;-) The important thing is that you are back up and running! Now, go make something good!
