WolfeStudios opened this issue on Feb 24, 2003 ยท 3 posts
WolfeStudios posted Mon, 24 February 2003 at 11:37 AM
Models that I construct and export from Rhino3D (3ds and obj formats) don't seem to hold textures in Poser5. If I render them in Rhino3D or Anim8or, the texturing and lighting effects appear. However, in Poser5, the model appears black and is not affected by lighting or reflection settings. I'm sure it's a simple fix. Any ideas why?
virtuallyhistorical posted Tue, 25 February 2003 at 11:21 AM
Someone cleverer than I will give you a better answer, but I think it's something to do with your vertices. Are you using UVMapper? If you are put it through there, press "weld vertices" and you should get the textures back. Seems .obj's need a little more work before being imported into Poser. I know this to be true of Poser 4. Then again.. this could be completely wrong! VH
electroglyph posted Fri, 07 March 2003 at 7:46 PM
