JHoagland opened this issue on Feb 24, 2003 ยท 6 posts
JHoagland posted Mon, 24 February 2003 at 9:14 PM
I have a question (or maybe problem) with UV Mapper: I'm trying to break apart a models materials so I can make separate templates. However, whenever I try, I get an error in UV Mapper saying "unknown file can not be found". Here's what happens:
Sue88 posted Mon, 24 February 2003 at 9:48 PM
I think you get that error message because you have something selected. If you want to have different texture templates for different parts of the object, do this: 1. Select the part(s) you want on the texture template, then go to Select/Display/Hide Unselected. Deselect all. 2. Save the texture template and be sure to check "Exclude hidden facets". 3. Now go to Select/Display/Show to display all the parts again. Select the next part(s) you want to texture separately and do the same steps (1-2) as before. HTH! Sue
Lyrra posted Mon, 24 February 2003 at 11:21 PM
Unless you are changing your obj NEVER EVER change anything in uvmapper. Your templates will NOT match your model, so there is no point. All you need to do is turn off visibility for the groups/materials you do not want, and then 'save template'. It should have an option for saving hidden materials in the template or not. (choose not)
Caly posted Tue, 25 February 2003 at 7:23 AM
Any good tutorials out there? :) Mac-based would be nice...
Calypso Dreams... My Art- http://www.calypso-dreams.com
JHoagland posted Tue, 25 February 2003 at 7:01 PM
I think you get that error message because you have something selected. Well, yes, I have the selected material selected. :) >i?Unless you are changing your obj NEVER EVER change anything in uvmapper. Your templates will NOT match your model, so there is no point. Actually, the method of resizing the head materials into an "empty space" and then saving the selection is part of tutorial on how to make textures for Vicky. I have no idea how it works, but when you save the resized head materials (to a 2000x2000 bmp image), it maps perfectly onto Vicky's head... without re-saving the obj file. However, this could be due to the fact that the template for Vicky is a square to begin with, so resizing and saving doesn't have any effect... as long as it's proportionally a square. I tried the suggestion to click on "Exclude Hidden facets" when saving the file... and it worked perfectly! The resulting image map was only the one material! Thanks! Now I can texture my models a lot easier. Maybe I'll remap my TARDIS in the Free Stuff... or maybe the picture frames... --John
Sue88 posted Tue, 25 February 2003 at 9:24 PM
You're welcome; I'm glad it worked for you. About the error message, what I meant was that nothing should be selected when you are saving the texture map otherwise you'll get that message. Have fun remapping! Sue
