Although you can't animate poser figures in bryce, you CAN do a fair job of simulating bryce in poser. Bryce exports terrains and symmetrical lattices as .obj files, and it even creates the texture maps for you from the bryce materials you used. you can't export boolean objects from bryce, however. the trees you see in the images above were modeled in ray dream studio, and have a bryce tree texture applied to the branches. and the dirt roads were applied to the ground texture in photoshop. the 'background' plane has a bryce render as it's texture. this is a set from an animation I'm currently working on.
Clever trick. You would probably get better feedback if you also posted this in the main poser forum.
