Subject: If you can't go to the mountain, bring the mountain to you......
brainmuffin opened this issue on May 13, 2000 ยท 3 posts
brainmuffin posted Sat, 13 May 2000 at 9:24 PM
Although you can't animate poser figures in bryce, you CAN do a fair job of simulating bryce in poser. Bryce exports terrains and symmetrical lattices as .obj files, and it even creates the texture maps for you from the bryce materials you used. you can't export boolean objects from bryce, however. the trees you see in the images above were modeled in ray dream studio, and have a bryce tree texture applied to the branches. and the dirt roads were applied to the ground texture in photoshop. the 'background' plane has a bryce render as it's texture. this is a set from an animation I'm currently working on.
Viomar posted Sat, 13 May 2000 at 10:46 PM
Very interesting technique... the bottom pic is "worth a thousand words..." or a tutorial! Thanks!!
Darth_Logice posted Sat, 13 May 2000 at 11:19 PM
This technique is very inspirational, as I am only now just trying to learn bryce. Thanks for sharing it! -Darth_Logice
