benjamino opened this issue on Feb 27, 2003 ยท 6 posts
benjamino posted Thu, 27 February 2003 at 9:59 AM
benjamino posted Thu, 27 February 2003 at 10:01 AM
benjamino posted Thu, 27 February 2003 at 10:06 AM
JayPeG posted Thu, 27 February 2003 at 1:13 PM
Looks like your face map is set to PROJECTION MAPPING/FLAT MAPPING. It's projecting the face on to the head object much like a projector would project a movie onto a screen. If you moved the screen, the movie would not move with it. Instead, set it to PARAMETRIC MAPPING. This will solve the problem. You may need to use a RECT LAYER to get to get the face to the proper position but once you do it will move along with the head object.
benjamino posted Fri, 28 February 2003 at 5:50 AM
thanks for this advice, i will try this. benjamino
benjamino posted Mon, 03 March 2003 at 9:16 AM
hello, yes, i tried this, and it worket. BUT: when i put a rectangle over the head - Sphere, it makes a very complicated form, so i can not project a rectangle map (movie) on the sphere. therefore i tried to put on an eliptical layer and this works better. but now: the layer is not showed very clear. there are lines in the showed movie, that have al ot of pixels now. what would be the best resolution (128 * 64 px and a depth of 72 dpi or something like that) to project the movie clearly in the eliptical layer. thanks for your experiences... benjamino
