Dana_CH_AZ opened this issue on May 14, 2000 ยท 6 posts
Dana_CH_AZ posted Sun, 14 May 2000 at 5:17 AM
I am looking for medival type house. Even a couple of buildings. I would model them myself if I knew what I was doing.:) Any luck?:)
rbtwhiz posted Sun, 14 May 2000 at 5:27 AM
www.geo-metricks.com Check the library "structures" section. -Rob
Jon posted Sun, 14 May 2000 at 5:44 AM
Have you been to www.wiremonger.com? No building but most of the associated contents are there with texture and bump maps included. If you want indoor scenes, you can use square props with textures for the walls.
jnmoore posted Sun, 14 May 2000 at 9:41 AM
http://www.poserworld.com/models9.htm and http://www.poserworld.com/models10.htm. Also a wishing well, old style cottage, etc a few pages back from these. The insides of the castle are beautifully textured by renapd over at FairyWoods. The castle is Canoma format, so will drop right into Poser real easy. -Jim
DanR posted Sun, 14 May 2000 at 2:29 PM
For a couple of medieval houses, a castle and a cathedral try http://www.3dtotal.com/ffa/meshes/mesharchitecture.htm Good Luck Dan
Dana_CH_AZ posted Sun, 14 May 2000 at 2:42 PM
Wow thanks y'all.:)
