Subject: Did You Flunk the Pbooost Compatability Test on XP Home?
Strixowl opened this issue on Mar 03, 2003 ยท 24 posts
Strixowl posted Mon, 03 March 2003 at 8:27 PM
If you did, and have already purchased it, did you try the XP Home Edition Program Compatibility Wizard? Might want to check it out and see if it will run properly under other older Windows versions in XP. Check it out. I haven't bought it (Pbooost)yet because I flunked the test :-( or I would have. The Libraries are driving me NUTS!! _________________________________________________ To run the Program Compatibility Wizard In XP Home Edition Start the Program Compatibility Wizard. (Click Start, click Help and Support, click Fixing a problem, click Application and software problems, under Fix a problem click Getting older programs to run on Windows XP, and then click the Program Compatibility Wizard link in the instructions.) Follow the instructions in the wizard. The wizard prompts you to test your program in different modes and with various settings. For example, if the program was originally designed to run on Windows 95, set the Compatibility Mode to Windows 95 (many others), as shown in Figure 2 below (a pic of a button saying Runs in Win 95), and try running your program again. The wizard also allows you to try different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels. The wizard will launch your program with the selected settings, and allow you to test how the program works. The final page of the wizard enables you to select whether to permanently apply the compatibility settings, abandon the changes, or save them and run the wizard again to apply different settings. It is likely that you will need to repeat this process until you find the correct Compatibility Mode. Has anyone tried this????
queri posted Mon, 03 March 2003 at 11:16 PM
Nope-- I bought PBoost anyway, even though I had XP-- it does seem to work fairly well on NTFS files. Won't work on Fat 32. Emily
c1rcle posted Tue, 04 March 2003 at 3:22 AM
I have XP Home on NTFS too & PBooost works perfectly has done since I bought it months ago. I didn't need to fiddle with the Compatability Wizard either, in fact I've had only 1 program that needed the settings changed in the year I've had XP. It's a good point tho, I wonder if the Compatability Wizard is in Win2K as well (seems to be the worst for not liking PBooost) maybe someone with it will let us know.
MindVision-GDS posted Tue, 04 March 2003 at 4:18 AM
No compatibility wizard in win2k. Win2k was originally NT5 but microsoft prolly didnt finish winME in time for the 2000 release so they renamed NT5 to win2k. Being an office OS based on the NT kernel win2k lacks DOS resources needed for (at the time anyway) many PC games. If you ask me..and I'm sure noone does..winXP is yet another slowed down OS by all its bells and whistles like the win9x tradition way up to winME and just getting worse. Dont mind me..I need coffee :)
RealDeal posted Tue, 04 March 2003 at 4:25 AM
I tried the compatibility tester, it says there is a problem with file locking, I believe. the main answer for this problem I have received is that I'm running a drive in FAT32 mode (which I am, I have one drive set up for Win98SE dual-boot). However, I'm thinking most likely it's because of having write-behind cache disabled on my temp directory; I did this in order to maintain a stable filesystem that could handle power outages, etc. This would in effect "lock" the file system; it doesn't appreciate things being written too while they are open. This could, I believe, keep Pbooost from properly working while poser was loaded. Which is really a shame, it looked sooooooo cool. I geuss I'll just keep using my bat files to rename directories.
c1rcle posted Tue, 04 March 2003 at 4:43 AM
MindVision I have all the bells & whistles switched off & you wouldn't believe how much faster it is without them, why they insist on having the things switched on as default is beyond me, they really are a waste of time & resources.
cruzan posted Tue, 04 March 2003 at 7:44 AM
have xppro dual boot with 98se on seperate disks and Pboost says it failed (probably due to fat32 on all disks) but since I had a new dedicated xppro; figured I would buy it anyway and run over network to control P4library.... Then I forgot what I was going to do (run thru lan) and installed it on my dualboot system and it worked (now dont have to fight wireless lan time). PPP is loaded on fat32 with xppro and not on the win98se boot disk - if that makes a difference?..? Of course when I boot 98se - pboost doesnt load but it wasn't installed for that.
Dragontales posted Tue, 04 March 2003 at 9:50 AM
How do I check how my drives are formatted? I bought a laptop with xp and don't know which way it's formatted. I'd like to get Pboost as well.
c1rcle posted Tue, 04 March 2003 at 9:56 AM
go into explorer right click on the drive & select properties it'll tell you in the window that pops up which way you're formatted :)
Strixowl posted Tue, 04 March 2003 at 10:28 AM
C1rcle, Thanks for the info on how to check on drive formatting. Couldn't even find that at Micro S--ks site. Whats crazy is my XP Home Ed IS formatted for NTFS and I flunked the Pboost Test.....Anybody have any ideas???
Dragontales posted Tue, 04 March 2003 at 10:56 AM
Thanks for the info, and my drive is formatted NTFS as well. Will I be able to use PBooost?
SamTherapy posted Tue, 04 March 2003 at 11:40 AM
I use XP Home with NTFS, tried the test, all passed after running Correct Reference. I'm now using PBooost with no problems.
Dragontales posted Tue, 04 March 2003 at 11:42 AM
Sorry, but what do you mean by Correct Reference?
SamTherapy posted Tue, 04 March 2003 at 11:53 AM
It's another application in Freestuff; a companion piece to PBooost. It searches through Runtime and corrects incorrect references to texture flies. My understanding of the file locking problems in Poser are that they are caused mainly by an object trying to reference a texture file when the specified path is incorrect.
Dragontales posted Tue, 04 March 2003 at 12:47 PM
Gotcha. Thanks a bunch!
c1rcle posted Tue, 04 March 2003 at 2:28 PM
Attached Link: The Netherworks
CorrectReference is currently being hosted on The Netherworks site. Further to what SamT wrote, when a texture is missing or in the wrong place, poser goes through every folder under textures looking for the texture it wants, but it has a nasty habit of keeping the folders open so when PBooost tries to switch banks it can't because Poser still has hold of them. Once CorrectReference is used on the library folders Poser no longer has to hunt the texture it goes straight to the right folder without opening every other folder hence no more locked folders.
TrekkieGrrrl posted Tue, 04 March 2003 at 4:09 PM
Whew just wanted to say that running a CorrectReference on your runtime can take a helluva time... I started mine at 2 pm and now at 11 pm (!!!) the balsted thing is STILL running. Oh and it IS running, correcting references and all...but whew.... and that's on a 12Gb runtime.... so beware if your runtime is in that size - or bigger...
SamTherapy posted Tue, 04 March 2003 at 5:29 PM
Oh yeah, that's entirely true for the first time you run it. If you try it again at a later date, it won't take nearly as long. Also, the latest version of PBooost allows you to correct the references internally.
Dragontales posted Tue, 04 March 2003 at 6:43 PM
Question, What happens if an item looks for textures that are no longer there? Will correct Reference change it, or leave it blank. I lost a bunch of textures on a computer changeover a while back and don't want to try and reinstall everything. I retexture in another program anyway, so it's not a big deal if the textures are missing. I'd just like to know what Correct Reference would do to the items. Thanks
Spit posted Tue, 04 March 2003 at 8:21 PM
If CR can't find a texture with the same name (beware of textures named black.jpg for example) it adds it to a list of textures not found. Then when it's finished you can either find the textures yourself for the items in the not found list, or set them to NO_MAP.
classic posted Tue, 04 March 2003 at 11:26 PM
My installation of Poser failed the Pbooost Compatability test. The weird thing is my Poser folder is on a NTSF partion along with my operating system. I though the locking problems only shows up if you installed Poser on a FAT 32 partion and have NTSF partions as well.
TrekkieGrrrl posted Wed, 05 March 2003 at 12:13 AM
SamTherapy, it did TELL me to change it internally, but it didn't tell me HOW LOL And that deep File editor... well it looked nifty but I didn't have a clue on what to do, so I decided to run CR :o) Took it 10 hours to finish, but will you LOOK at my Texture folder now :oD Everything is in neat li'l folders now. Now Poser can find everything...and I can't find anything LOL
c1rcle posted Wed, 05 March 2003 at 3:11 AM
classic I'm using NTFS but when I first got PBooost I had the problem with locked folders, then a few weeks later Howard brought out CorrectReference & it solved the problem, it also speeds up poser when loading textures & figures with textures already assigned. ernyoka I should've said if you have a big runtime you should do it a bit at a time, the only folders that really have to be checked are character, pose, hair & props. you only need to check the others if you've put mat poses in them.
Dragontales posted Wed, 05 March 2003 at 10:39 AM
I'm running CR right now. It's great. Definately speeds up poser.
