prinzeugen12 opened this issue on Mar 05, 2003 ยท 3 posts
prinzeugen12 posted Wed, 05 March 2003 at 12:09 PM
Hello Forum, I was working on a scene where an Amazon warrior is about to have at a Ghoul that is leaping at her from a rock. I an still pretty new with Vue. I was happy with everything. I lined everything up, put the vegetation were I wanted and called it a night.. I saved the scene..Next day I decided to import a new Ghoul and have him lying dead near the rock half out of fog..trouble is in four pane view he's by himself. In the main View he is a tiny little speck in the far distance..How do I get him up front and center where everything else is??? Did the same thing with Vegetation..tried to add a fern to the forground..it too was a tiny little speck in the distance..When I opened this scene the day before and built everything up it all showed up in the four pane view so you could grab it and move it around.. What gives?? regards PE
sittingblue posted Wed, 05 March 2003 at 2:20 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12368&Form.ShowMessage=1131579
Check out this previous thread. This sure sounds like the same problem.You can always manually move it to the scene by typing in 0,0,0 (or whatever is appropriate) in the object's coordinates controls.
Charles
Charles
amon_g posted Wed, 05 March 2003 at 2:44 PM
Ah... I guess I DO need to sleep a little:) I turned off the resize and center object option and the Poser import ended up way out in la-la land... but I didn't even think of using the numeric entry to center the object manually. D'oh! ~ brent ~
