ldtroisd opened this issue on Mar 05, 2003 ยท 6 posts
ldtroisd posted Wed, 05 March 2003 at 4:26 PM
2 questions please
I'm french
---I buy poser 4.0.3 and pro pack english
i have a PC with XP PRO and i cant install pro pack(english)
(is it possible propack doesn't goes on with XP)
---with the cd the plug in light wave is for V5 to 6.5
where is the plug in for 7.5 please.
thanks
pink999 posted Wed, 05 March 2003 at 4:43 PM
Do you have a downloadable version of PP or the boxed cd? Also what exactly happens when you try to install the propack?
casamerica posted Wed, 05 March 2003 at 5:09 PM
I wish I could help you more, but I use Poser 4 and Pro Pack with WinXP and have had no problems. Is your copy of Poser 4.0.3 also English? I believe I remember there being an issue with trying to mix the various language versions of Poser and Pro Pack. Take care, be well, keep flying. casamerica
ldtroisd posted Thu, 06 March 2003 at 12:36 AM
1/i open pro pack set up
2/the window install is open i choose next
3/then a window (the installer will search your systeme for poser 4.depending of the size of your hard disk)then OK
4/ a window (searching for poser )
and the install stop
the window to send a rapport to XP OPEN
IN THE CD THER IS
3DS PLUGIN INSTALL
DAZ PRODUCTIONS
DOCUMENTATION
FLASH EXAMPLES
HOUSE OF MOVI
LW PLUGIN iNSTALL
VIEWPOINT-INFO
PROPACK STE UP (28.1 Mo)
READ ME
poser pro pack and poser4.0.3 are in english
thanks
pink999 posted Thu, 06 March 2003 at 4:45 AM
Maybe try cancelling when the install looks for poser install and you should be able to assign it manually then...
casamerica posted Thu, 06 March 2003 at 7:41 AM
Ah, I had the same thing happen when I first installed ProPack. Do as pink999 states - locate the Poser.exe file manually. That is what I had to do also. I have no idea why the PP could not find it, but since installation I have very few burps with ProPack. Take care, be well, keep flying. casamerica
