szeven opened this issue on May 16, 2000 ยท 5 posts
szeven posted Tue, 16 May 2000 at 2:29 AM
LoboUK posted Tue, 16 May 2000 at 3:47 AM
The problem here is that the ring is parented to the head, there is no eyebrow to parent it to. So, when you raise the eyebrow, the position reference for the ring doesn't change - it's still parented at XYZ, even though the eyebrow is now at XYZ1 The only fix I can think of for this would be to physically move the rings up to the new eyebrow position. Paul
CharlieBrown posted Tue, 16 May 2000 at 9:48 AM
Could you define the Eyebrow as a new material with the Grouping Tool, and parent the ring to it then? I haven't played a lot with the grouping tool, so I'm not sure if it can work this way or not...
LoboUK posted Tue, 16 May 2000 at 10:30 AM
That might work, I'll give it a go tonight and see Paul
szeven posted Tue, 16 May 2000 at 1:33 PM
o.k., I'll try the grouping tool.
