josiahpugh opened this issue on May 16, 2000 ยท 2 posts
josiahpugh posted Tue, 16 May 2000 at 8:17 AM
How do I set the transparencies in Photoshop 5.5 for the web?? Thanks.
dagar posted Sat, 20 May 2000 at 3:38 PM
By transparencies for the web I will assume you know that you will need to have the transparencies in place within the image. You will then goto File: Save for Web....and choose gif under format and make sure the Transparency is checked off on the right side of the window. Then click ok...you can also play around with the gif settings but make sure the transparency is check and you will have a transparent gif. Happy rendering Dagar
