Subject: freebies...
modelsrus opened this issue on Mar 08, 2003 ยท 19 posts
modelsrus posted Sat, 08 March 2003 at 4:07 AM
Hi. I am a newcomer to the wonderful world of 3D. Less than one week so it's a heavy learning curve for me ! I know Photoshop inside out but Poser is something unique. I have downloaded a few 'freebies' from sites but don't know how to get them into Poser 4. Please can someone let me into the secret. Regards Chris.
leather-guy posted Sat, 08 March 2003 at 4:48 AM
Attached Link: http://market.renderosity.com/~pzr/backroom/index.htm
Click on this link. Takes you to the Poser Forum Backroom (also accessible from the Poser Forum Masthead above). Click on FAQ 1st Q & A is your question.
Philywebrider posted Sat, 08 March 2003 at 4:56 AM
Are you asking how to install the freebies into poser, or how to get the freebies into/onto a scene/figure after they are installed?
tasquah posted Sat, 08 March 2003 at 8:49 AM
Welcome aboard . If you needed help installing them into poser here is Dr Geeps visual reference of were everything goes.
melanie posted Sat, 08 March 2003 at 9:13 AM
Many of the freebies are self-installing. If you open the zip and find the paths there, all you have to do is unzip the files into the Poser 4 root directory and all the parts will fall into the correct folders. Also, read the readme files that come in the zips. Hopefully, most artists are including instructions on how to install that particular freebie. Welcome to Poser! You're going to have a blast with it. Melanie
nwmione posted Sat, 08 March 2003 at 10:44 AM
The most important seem to be Obj files. Some go into Geometries + some sub-directory and some into a specific Morph directory. If Poser cannot find these when you open a character of file, Poser locks up something awful. If Poser cannot find some other file, it's no big deal, but make sure these Obj file locations are correct.
Philywebrider posted Sat, 08 March 2003 at 11:26 AM
Create "Download" File. Down Freebies (zip) to "Download" file Unzip Freebie to "unzip" file I open "unzip" file I open Poser's file>runtime>...you should get a list (see tasquah sample image) After draging items texture/object from unzip to texture/object in poser. Clip on "libraries" in Poser Clip on "libraries" in "unzip" Drag approprate file/folders Pose, Props, Camara, Lights, Characters, etc, from "Unzip" to "Poser". If there are no folders, check the read me to see where the files go. I hope I didn't make it too confusing. There are proably better ways, but I know where everything is this way.
Philywebrider posted Sat, 08 March 2003 at 11:27 AM
balaoo posted Wed, 09 July 2003 at 9:42 PM
I've found useful to have External Libraries. I've made a "C:PoserFiles" folder where I keep the dowloads, organized in subfolders. When it gets a size of about 500 Megs, I record a CD with them, clean the PoserFiles folder and begin again. I keep a text database of what each CD has, and I can also browse trough the CDs with P3dO In this way, the Poser folder doesn't get oversized. The props can be imported directly For the characters, I keep in their CD folders: a) a pz3 version to import, so I don't have to drag neither cr2s nor rsrs; b) the eventual specific textures, which Poser finds without trouble; c) the eventual geometries,which I drag to Runtimes> Geometries before importing the character (recorded with the eventual conversions from pcfs already made); d) the eventual bump files as bumpfiles (huge to store in the hard disk)--- Hope somebody finds it useful / Hope somebody helps me to improve my method /Hope everybody forgives my English (Mi idioma es el espal)
amanda_a42 posted Tue, 26 August 2003 at 1:03 PM
Sometimes you just have no idea where the OBJ should go... I have encountered this situation many times, and other times the path on the ZIP file is not correct. Do you know of any way how to determine where the OBJ should be?
tasquah posted Wed, 27 August 2003 at 10:06 AM
Amanda: If you want to know were a OBJ is suppose to go , the easyest way is to open the CR2 file with a text program like word . You will see something like this inside : ------------------------- {version { number 4.01 } figureResFile :Runtime:Geometries:DAZPeople:blStephanie.obj ----------------------------- this says go to the runtime folder "Geometries" look for a folder there called "DAZPeople" and thats were you will find the OBJ called " blStephanie.obj " these folders names are case sensitive so if you make it your self it has to be exactly the same. "DAZPeople" is not the same as "dazpeople" .
aragon007 posted Sat, 27 September 2003 at 9:50 PM
Finally Some sense into this mad maze created by poser
tyllo posted Wed, 02 June 2004 at 11:43 AM
HALLLOOOOO!!!!Any Moderator???? Post from a scum that call himself "oodimitriosoo" has a ugly porn link! I think it's the best delete it at once (such links can contain virus or other nasty plaque...)! -Teresa Tyllo
aragon007 posted Wed, 02 June 2004 at 7:58 PM
??? MODERATOR ???
Philywebrider posted Thu, 03 June 2004 at 12:13 PM
Three Moderators, two Coordinators.
aragon007 posted Thu, 03 June 2004 at 1:49 PM
Does any of them Moderate or coordinate, or do they just have a title ?????
leather-guy posted Thu, 03 June 2004 at 3:28 PM
"Does any of them Moderate or coordinate, or do they just have a title ?????" Yes they do. What they DON'T do is search constantly thru ancient threads for random comments asking for their attention. If you want a moderator or coordinator's attention, click on the link(s) in the masthead and send them an IM with a link to the thread you're concerned about. Same with New Threads - An IM is the quickest way to get them, and remember, they're not all online 24/7 either, if it's an urgent matter, send IM's to several, with an explanation why you feel it's important.
SndCastie posted Thu, 03 June 2004 at 7:43 PM
Thanks for the heads up Shanna took care of the post. Like leather-guy suggests anytime there is a problem feel free to contact one of us through IM we are here to help in any way we can. :O)
Sandy
An imagination can create wonderful things
SndCastie's Little Haven
hauksdottir posted Thu, 03 June 2004 at 10:13 PM
Sorry for not sweeping through here earlier. My migraine has been kicking up badly, so I've spent most of the last 2 days trying not to think. I just logged on and got and checked IMs. That is the best way to call our attention to something. That virus which attaches porn links is pretty nasty, and we should probably pull out the thread where the fixed is laid out and stick it up in the FAQs or some other easy to find place. :sigh: Carolly
