Bidsy opened this issue on Mar 08, 2003 ยท 4 posts
Bidsy posted Sat, 08 March 2003 at 5:10 PM
Q. How do you put a texture/reflec/bump map onto the GROUND plane in Poser? have tried with no success (i'm sure there's a simple answer!). Thanks in advance. Dave
GraphicFoxx posted Sat, 08 March 2003 at 5:35 PM
The ground plane already has a texture on it. Just go to the paramater window, and check the 'visible' mark. It's set to invisible by default.
bloodsong posted Sat, 08 March 2003 at 6:08 PM
heyas; ctrl-g is faster to turn the ground plane on/off. what are you doing, bidsy, and what is it failing to do? if you turned the ground on (visible), then just changing its texture like any other poser texture ought to do it.
Bidsy posted Sun, 09 March 2003 at 6:51 AM
Thanks guys - I did what GraphicFoxx said and its now working - thanks a bunch fellas!!
