electroglyph opened this issue on Mar 12, 2003 ยท 11 posts
electroglyph posted Wed, 12 March 2003 at 3:59 PM
treemont posted Wed, 12 March 2003 at 4:06 PM
i had a similar problem before, so i'd like to hear the solution as well
Aldaron posted Wed, 12 March 2003 at 4:06 PM
Does the photo in the background have some transparency to it? If it does it looks like the ground plain is showing through. You could delete the ground plane or get rid of the transparency.
Incarnadine posted Wed, 12 March 2003 at 4:09 PM
if there is any reflectivity in your scene you will have to allow for the presence (or lack of) of things behind the observer/camera.
Pass no temptation lightly by, for one never knows when it may pass again!
AgentSmith posted Wed, 12 March 2003 at 4:37 PM
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
AgentSmith posted Wed, 12 March 2003 at 4:38 PM
And, if you're not using your infinite plane, which you shouldn't in interior scenes, make sure it is deleted. AS
Freestuff | IMDB
Credits | Personal
Site
electroglyph posted Wed, 12 March 2003 at 5:35 PM
GROINGRINDER posted Wed, 12 March 2003 at 7:41 PM
Is this for a punch press?
Noel posted Wed, 12 March 2003 at 8:45 PM
Maybe group everything [I mean everything - objects, lights, camera - everything] together. Now rotate the whole thing down 90 degrees. Voi-la! No horizon there!
electroglyph posted Thu, 13 March 2003 at 11:17 AM
It's just for stamping out hollow spheres. The punching is done elswhere. Changing the lights from square spots to radial lights seems to have fixed everything. I had cast and recieve shadows off, and the angle from the lights to the 2D backdrop was high enough that the shadow should have passed above the backdrop. It still somehow made a difference. I used square spotlights in my christmas scene. The light didn't pick up the stained glass colors even though it was loaded into the volume channel. It also didn't pick up the shape of the window when I had cast shadows selected for the walls. I wound up applying as a gel and putting up pine trees so you could not see the tops of the windows were square instead of curved. Special bryce lights have special quirks. Someday I'll figure them out.
pakled posted Fri, 14 March 2003 at 4:46 PM
tell me about it. I've been known to do the 'rotate the horizon outta here' bit meself..;) If only I had the time to play with it..;)
