JerryLee opened this issue on May 18, 2000 ยท 6 posts
JerryLee posted Thu, 18 May 2000 at 9:55 AM
JeffH posted Thu, 18 May 2000 at 3:11 PM
Those don't look like the standard Poser eyes, they probably take a separate map all together. Can't say for sure since I don't have that figure. -JH.
andyjlee posted Thu, 18 May 2000 at 8:52 PM
You've definitely got to produce a seperate map for the eyes.
andyjlee posted Thu, 18 May 2000 at 9:09 PM
Sorry just checked the map in UV Mapper. Seems you'll need to redo the whole map as although NewEve is based on the P4NudeWoman, the map layout has extra parts added, and some parts are moved to other areas. Get/Use UV Mapper and you'll se what I mean.
leeroy5 posted Fri, 19 May 2000 at 3:38 AM
jerry trave have a specali map make for the eyes call blueeyes i think. if you say the p4 texturmap-body going for all (i mean the little klick) so you have that problem. i have it too...
JerryLee posted Tue, 23 May 2000 at 3:04 AM
I got it guys...thnx...tho there was no such texture, the eyeballs needed a seperate texture too. -Jerry-
