dmayberry opened this issue on May 19, 2000 ยท 4 posts
dmayberry posted Fri, 19 May 2000 at 8:20 PM
Does anyone know how to delete or not have certain parameter dials? Such as x rotate or y translate etc. Iknow about setting limits on dials.However some models I'm working on only need like 1 rotate doesn't need any thing else.
Cage posted Fri, 19 May 2000 at 8:35 PM
You can turn a given dial on or off by editing the cr2 in a text editor. The "on" and "off" position for each dial is represented by a one or zero in the channels section for that parameter. Unfortunately I haven't done this in a while and I don't remember the details as to which line you should look for....
Cage can be an opinionated jerk who posts without thinking. He apologizes for this. He's honestly not trying to be a turkeyhead.
Cage had some freebies, compatible with Poser 11 and below. His Python scripts were saved at archive.org, along with the rest of the Morphography site, where they were hosted.
ScottA posted Sat, 20 May 2000 at 8:36 AM
In the .CR2 file. You'll need to first search for the body part name you want to edit the dials for. Once you've found it. There is a line called "Channels" a little ways down the file. There are several names of dials,translate,rot,offset, ect. these are all types of dials. a few lines of text below each of those names you'll see a word called "hidden". There will be either a 0 or a 1 directly after it. 1=dial visible 0=dial invisible ScottA
dmayberry posted Sat, 20 May 2000 at 4:03 PM
Thank you kindly! I knew there was a way just couldn't recall hearing about it
