Subject: Poser 4 cannot open my obj
cmjackson opened this issue on Mar 21, 2003 ยท 3 posts
cmjackson posted Fri, 21 March 2003 at 1:45 PM
I've just purchased PhilC's V3 lingerie and when i try to open the g-String in the figures libary Poser 4 says it cannot open the obj and it cannot open the resource file leading to the obj. I've tried re-installing Poser 4 and i've tried extracting the file again but it won't work, i can though go to file,Import obj and open it that way but then it won't conform. I had this problem with one other conforming figure (can't remember what it was though). The g-string worked fine to start with but i got the problems after opening it a few times. Can anyone help?
thgeisel posted Fri, 21 March 2003 at 1:51 PM
in poser 4 every obj file has a corresponding *.rsr-file. It has the same name as the obj file and is in the same directotry as the obj file. delete the *.rsr file. poser will build a new one next time you load the figure.the rsr files sometimes get damaged
cmjackson posted Fri, 21 March 2003 at 2:08 PM
Excellent it worked i thought a RSR file was just an image file
