LadyBea32 opened this issue on Mar 25, 2003 ยท 8 posts
LadyBea32 posted Tue, 25 March 2003 at 9:46 AM
LadyBea32 posted Tue, 25 March 2003 at 9:47 AM
-Waldo- posted Tue, 25 March 2003 at 9:52 AM
It is normals bug. Poser don't reveal one side of the prop. Please report to curiousLAbs about this. Waldoo
-Waldo- posted Tue, 25 March 2003 at 10:03 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1156512
Check my thread about the Normals Bug http://www.renderosity.com/messages.ez?Form.ShowMessage=1156512LadyBea32 posted Tue, 25 March 2003 at 10:45 AM
well one i dont use p5, i use propack. also im not having a problem with the texture map, i dont know if i have to make the texture maps before i load the model, or is there a way to do the whole thing including the panels after its loaded. your thread, totally confused me though
Tashar59 posted Tue, 25 March 2003 at 3:24 PM
If you UV the parts first then put them together, export as obj., import back in, that will work. You only need to map one of the parts that you use, just import the UV obj. as many times that you need it. eg. the top of the bed post has 4 ends but you only need 1 UV obj. to import to make all 4 ends, but 1 map for the four parts. Read Dr. Geeps tutorials on the grouping tool. That will help you a lot. Just look up geep. Hope this helps. Tashar 59
LadyBea32 posted Tue, 25 March 2003 at 3:38 PM
i got it, caleb helped me out by making the bed into a figure. have all the morphs loaded to and everything works. now i just need fix the uv map and im set. thanks for trying to help thoug. beryld, i dont quite understand the grouping tool enough yet to want to mess with it. i tried it before and well lets just say a week of messing with it and not getting anywhere rather discouraged me from touching it anymore. hugs bea
