Forum: MarketPlace Showcase
Subject: Masquerade for Vicky 3 now Available!
Morris opened this issue on Mar 26, 2003 ยท 6 posts
Morris posted Wed, 26 March 2003 at 8:40 AM
Attached Link: http://market.renderosity.com/softgood.ez?ViewSoftgood=18292
Introducing Masquerade, a hi-resolution photo real texture/character package for Vicky 3 by Visual Silence.
You MUST own Victoria 3 Base and both the head and body morph packages to properly use this package. These items can be purchased through DAZ3d.com
The MOR poses will inject the correct Morph targets and set the values to set up your Anna character. However, in order to utilize the expressions for Anna, you will need to use the injection pose located in the following directory, Poses/!V3 Expressions INJ.
To install this package simply locate your Poser 4 folder and unzip, the files are already set to create and load into the proper folders.
In this package you will find:
1 Mor pose that will inject all required morphs and create the Anna character
1 Mor pose that will only inject and set the head morphs for Anna
1 Mat poses to apply the default Anna textures
7 Mat poses to apply the extra Make-up, change of eye colors and Masked faces for Anna
1 Anna Body texture map (3000x4000)
8 Head texture maps for Anna (4000x2719)
1 Teeth texture map (900x900)
12 Eye texture maps (1000x1000)
1 Transparency map (2000x2000)
Renders created with Global Lighting from DAZ, the only postwork is some sharpening after resizing the renders to compose together.
Morris posted Wed, 26 March 2003 at 8:41 AM
SAMS3D posted Wed, 26 March 2003 at 11:18 AM
This is spectacular.....I am there!!!! Sharen
Rhiannon posted Wed, 26 March 2003 at 4:14 PM
Very unique character, and lots of options for many looks here ... can't wait to play with her Jen, she's gorgeous!
pendarian posted Thu, 27 March 2003 at 12:16 PM
Absolutely wonderful work!!!
Aery_Soul posted Thu, 27 March 2003 at 3:50 PM
I agree, the character is really unique and those make ups are simply amazing!!!
www.aerysoul.com
