pigfish opened this issue on Mar 26, 2003 ยท 9 posts
pigfish posted Wed, 26 March 2003 at 5:38 PM
I'm so used to hitting the escape key to cancel renders in Bryce that I, unthinkingly, did the same while rendering in Poser 5. Not only did it work, the render stopped much faster than it does when you hit the cancel button in the pop up box. It may have just been a fluke but I hope not. Anyone else had this same experience?
Little_Dragon posted Wed, 26 March 2003 at 6:07 PM
The Escape key works in Pro Pack, also.
Simderella posted Wed, 26 March 2003 at 6:28 PM
yep... i always use the esc key in both PP & P5
Momcat posted Wed, 26 March 2003 at 7:27 PM
You actually got a render to cancel in P5 without it freezingup?
Very good to know. I'll have to try that. Thank you >^_^
Marque posted Wed, 26 March 2003 at 8:42 PM
Good tip thanks! Marque
sandoppe posted Wed, 26 March 2003 at 9:47 PM
It works sometimes.....but not always :) I'm use to the "escape" key as a Vue user, so it was natural to try it in P5. The first time it worked fine, but P5 is an odd duck.....there is no continuity it seems about what works....and what doesn't. I'm sort of getting use to it though :)
who3d posted Thu, 27 March 2003 at 11:16 AM
Good programming practise has the escape key & Cancel button both work - to do the same thing. Both basically mean "Argh! I don't wanna do that after all, stop, halt, cease!". I have a sneaky suspicion you were just lucky on timing :(
BeatYourSoul posted Thu, 27 March 2003 at 12:03 PM
I've had no problems with cancelling renders in P5 since updating to SR 2.1. Maybe I'm lucky too? :) BYS
neurocyber posted Thu, 27 March 2003 at 8:21 PM
I made that same mistake. Very happy discovery. :)
