Forum: Vue
Subject: Importing Victoria in Vue
martial opened this issue on May 22, 2000 ยท 5 posts
martial posted Mon, 22 May 2000 at 6:22 PM Online Now!
Bonjour!Just say that :for first time ,using new Vue beta 5 ,i can import a exported Poser file in Vue with all textures(Victoria morphs with jeans and t shirt and souliers) Same success with Camona files from Poserworld site .Only problem concerns eyelash part on Vic objet:Vue import millashes.jpg in colors,mapped picture parameter ,after i set transparency to 100% (or other %?) but the eyelashes are still too dark,not really transparent like in Poser.Must i set something in variable transparency parameter(using another pict mapping)or set other parameters?Thanks!I am on Pc and also i set the two eyeballs with 100% transparency
KateTheShrew posted Mon, 22 May 2000 at 11:57 PM
You need to reverse the colors on the eyelash transmap for Victoria and then use that in the variable transparancy setting in Vue. That should fix your problem.
arcady posted Tue, 23 May 2000 at 10:59 AM
Too bad Vue doesn't have a reverse colors option in it's materials editor.
Truth has no value without backing by unfounded belief.
Renderosity Gallery
KateTheShrew posted Tue, 23 May 2000 at 4:59 PM
Yeah, wouldn't that be a good thing to put on the wishlist?
KateTheShrew posted Tue, 23 May 2000 at 5:52 PM
I whipped up a quick tutorial on how to change the transparency filter so you don't have to reverse the poser transmaps. It's posted above. Sorry for the size of the graphic, but it's easier to follow with the pictures (especially if English is not your native language). Hope this helps you all out. Kate
