GigaRoc opened this issue on Mar 29, 2003 ยท 14 posts
GigaRoc posted Sat, 29 March 2003 at 3:04 PM
ockham posted Sat, 29 March 2003 at 4:37 PM
Interesting effect, and I hadn't thought about it before.... Poser doesn't "know" that the boxes are tiles in a single surface, so it treats each box as a separate object, shading it in the way that would look natural if it were standing on its own. Each flat surface is effectively bulged just a bit. (This is actually compensating for an oddity in human perception, in which edges are overemphasized.) The only way to make the roof and wall look "solid" is to build them as single solid objects, either by scaling up a single box or by building in another modeler like Anim8or.
raven posted Sat, 29 March 2003 at 4:42 PM
You could always export it out of Poser as a single .obj and then reimport it and give it the same colour.
GigaRoc posted Sat, 29 March 2003 at 4:55 PM
but then i lose the ablity to Add Texture maps to each section... don't i?
chanson posted Sat, 29 March 2003 at 5:04 PM
No, you won't You can use the grouping tool to define material sections (from one to many polys in a section). Geep has some tutorials on the grouping tool...
GigaRoc posted Sat, 29 March 2003 at 5:05 PM
Cool, thanks
Lyrra posted Sat, 29 March 2003 at 6:44 PM
I kinda like it this way actually ... give each panel a nice bumpmap for rivets and you've got some cool metal paneling
GigaRoc posted Sat, 29 March 2003 at 10:27 PM
none of that worked V_V i'm not about to rebuild it, and theres no way to turn it off or something?
geep posted Sun, 30 March 2003 at 2:53 AM
Attached Link: http://www.renderosity.com/messages.ez?&Form.ShowMessage=984971
Giga,You have "soft" edges on your boxes.
You want "hard" edges.
Poser bends the light (this is what you have) when going around an edge when the vertices are welded.
Check the attached link for additional information if you want.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Sun, 30 March 2003 at 2:59 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Sun, 30 March 2003 at 3:04 AM
cheers,
dr geep ... :o]
edited 10/5/2019
GigaRoc posted Sun, 30 March 2003 at 2:41 PM
Geep, howedya geet so smart? Thanks GigaRoc Peace
geep posted Sun, 30 March 2003 at 7:13 PM
Years and years and years of practice. ;=] (and lots and lots of trial and error) (more error than trials though) ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Sun, 30 March 2003 at 7:14 PM
What size do you want and I can give you the numbers to use in Poser. (if'n ya want) ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
