Forum: Photoshop
Subject: Anyone knows about a conflict between Flaming Pears and Photoshop 7?
Doublecrash opened this issue on Apr 01, 2003 ยท 7 posts
Doublecrash posted Tue, 01 April 2003 at 4:32 AM
Hi all, I would like to ask a simple question: anyone of you has encountered a problem between Flaming Pear Filters and Photoshop 7? I just installed the 7 upgrade and the FP filters keep crashing my session, specially when I use two (or more) in a row over the same image. They didn't have any problems at all with PS6. Anyone knows this and/or have a solution? Many thanx in advance.
dreamer101 posted Tue, 01 April 2003 at 12:12 PM
I've never had problems with Photoshop 7 and Flaming Pear Filters. Does this happen on a small filesize image as well?
Doublecrash posted Tue, 01 April 2003 at 2:23 PM
Yes, this happens with any kind/size of file. :(
SWAMP posted Tue, 01 April 2003 at 4:29 PM
The only FP filter I have is the "flood",and yes,I did have a problem.It didn't crash,it just wouldn't apply the effect. After I got another filter off their site,and useing my old key number from the first filter...it works perfect.I compaired the two filters,and found a slight file size difference between the two(must be a newer version?). Go DL replacement filters,use your key numbers,and see if that fixes it. SWAMP
Doublecrash posted Tue, 01 April 2003 at 6:29 PM
Thanx, I'll try it! S.
Doublecrash posted Tue, 01 April 2003 at 8:16 PM
Thanx again, SWAMP, this was the problem! I did as you suggested and now they're running smoothly again. Thanx so much. S.
SWAMP posted Tue, 01 April 2003 at 9:32 PM
Good..glad it worked. Have fun,SWAMP
