GROINGRINDER opened this issue on Apr 05, 2003 ยท 22 posts
GROINGRINDER posted Sat, 05 April 2003 at 5:12 AM
TheBryster posted Sat, 05 April 2003 at 5:49 AM
Love the plane, but the cbts need white and blue flashes/lens flares.... The Bryster
GROINGRINDER posted Sat, 05 April 2003 at 6:03 AM
Thanks for the input. I'll check out the white/blue idea, but pass on the lens flares. I am using a virtual camera, not a real one.
vasquez posted Sat, 05 April 2003 at 6:19 AM
the flame textures is good but need more light.
Erlik posted Sat, 05 April 2003 at 6:39 AM
The flames have to have more transparency and light. And to be shorter. Love the decal and the texture on the plane, btw. But why's the nose transparent? No machine gun there.
-- erlik
GROINGRINDER posted Sat, 05 April 2003 at 8:00 AM
Thanks vasquez and Erlik. Your ideas are good ones. Erlik the nose is transparent and there is a machine gun there. It is just out of ammo at the moment. LOL Right now I am re-rendering the scene per TheBrysters suggestions. I have included more light and transparency. I will post it here when it is done and we will move on from there.
croowe posted Sat, 05 April 2003 at 8:39 AM
If you are incorperating the Brysters suggestion for white and blue flashes I have seen Clay's Volumetric fire done in blue, once peaked might work quite nice for this. It used to be available in the free stuff here but is no longer. I had grabbed when it was available so if you want I could e-mail it to you. Its a rather nice mat, just a suggestion. Cheers
GROINGRINDER posted Sat, 05 April 2003 at 10:25 AM
Thanks croowe I already have it and will check it out now that you mention it.
GROINGRINDER posted Sat, 05 April 2003 at 10:45 AM
draculaz posted Sat, 05 April 2003 at 1:01 PM
more yellow :P
pakled posted Sat, 05 April 2003 at 1:21 PM
someone who has more knowledge correct me if I'm wrong, but I don't remember wing guns on this bomber (of course, I couldn't say if it was a B25,26..definitely not a 29..;) The 25, if I remember correctly, had several .50 machine guns in the nose, the other one had a nose mounted machine gun, with a guy in front of the pilot and copilot (there was a tank-busting version that had a 75mm cannon between the pilot and copilot, and you had to do some fancy footwork to dodge the recoil..;)
pauljs75 posted Sat, 05 April 2003 at 2:35 PM
Looks through Jane's Fighting Aircraft of WWII book Ahh... Here it is, Martin B-26C Marauder Medium Bomber... It would also be cool to have the tracers show if you get around to doing a wider angle shot.
TheBryster posted Sat, 05 April 2003 at 4:52 PM
I thought it was a B-17.......... Some artists depict gunfire as a series of pulses. Just a thought. The Bryster
catlin_mc posted Sat, 05 April 2003 at 5:43 PM
I think the second one looks more like shots firing from the canons but I go with Drac on a little more yellow. Catlin
sailor_ed posted Sat, 05 April 2003 at 8:31 PM
What's the shutter speed on that virtual camera. The props look all blurry ;-) Nice work!
GROINGRINDER posted Sat, 05 April 2003 at 9:11 PM
Thanks everyone. If I add the yellow to the blue the result will be green. Sailor ed look at props that are spinning and tell me they don't look blurry to you. I guess the shutter speed of my camera is the same as the human brain. I will try a render with the yellow and see where it takes me. Parkled the cannon are on the side of the fuselage under the cockpit and wing root. They may be mach guns, but I think they are 20 mm cannon.
pakled posted Sat, 05 April 2003 at 9:14 PM
ya learn somethin' every day..always a good reason to stop by..;) Should stop noddin' off on the History channel..;)
scotttucker3d posted Sun, 06 April 2003 at 12:29 AM
I like the prop alpha texture - maybe add a little thickness to it though to simulate the width of the angled prop blades. Either do this in post or try and do it by mapping to a disk with thickness and try a volumetric texture instead. looks cool! - Scott
pauljs75 posted Sun, 06 April 2003 at 12:51 AM
I this book is pretty cool... (Looking at Jane's WWII Fighting Aircraft again.) The profile of the canopy and the glass on the nose definitely makes it a B-26 Marauder. Powerplant: Two Pratt & Whitney R-2800-43 double row 18-cyl engines, 2000 HP each. Armament: Eleven 50 caliber machine guns. One flexible in nose (seen in this pic, the aircraft nose and this gun are what distinguishes this aircraft from others), four "package" guns in pairs (those other guns you see aren't on the wings, but are on pods on the sides of the fuselage), and the rest are on turrets (not seen in this pic.) Heheh... I thought that book would be handy for something.
GROINGRINDER posted Sun, 06 April 2003 at 1:20 AM
Attached Link: Historic Aviation
Thanks for the comments everybody. I should have stated from the start that it was Rhinofalcon's B26 model again. This excellent model will show up in alot of renders with my Hellcat and Mitsubushi Zero models which I am re-UV Mapping. I need to make some Me-109's and FW-190's.@pauljs75 I love all the Janes books. They are very informative and the most well researched of any out there. The Pratt and Whitney double wasp not only powered this plane, but the Hellcat, Corsair, P-47, and DC-6.
If anyone is into historic aviation go to www.HistoricAviation.com and subscribe to their warbird tech book club.
Incarnadine posted Mon, 07 April 2003 at 11:55 AM
looking good! The prop blur is very believeable. I might make the initial burst (at muzzle) a little smaller with a fuzzy edge to it. Rather good so far though!
Pass no temptation lightly by, for one never knows when it may pass again!
GROINGRINDER posted Mon, 07 April 2003 at 6:53 PM
Thanks Incarnadine I am still working on it.
