Forum: Carrara
Subject: How Do I Rotate A Sphere 360 Degrees?
nemisis opened this issue on May 25, 2000 ยท 8 posts
nemisis posted Thu, 25 May 2000 at 4:50 PM
Hi, I am trying to create an animation of a planet rotating. I have checked all tools and all I can find in (modifiers, constraints, etc) is the ability to move a sphere 180 degrees. How do you get a complete revolution??
ClintH posted Thu, 25 May 2000 at 5:56 PM
Spin the planets Yaw 180 degrees... Maybe set the animation for 5 seconds at 15fps... Move the timeline marker to the 5 second point. Select the planet and open the Properties window. Move the Yaw parameter 180 degrees from its current location. This should add a ekyframe at 5 seconds in the timeline. If you press the run button the planet should now spin.. That help? If not let me know. Clint
Clint Hawkins
(Zakk Wylde (2007))
keithw posted Thu, 25 May 2000 at 6:06 PM
You can apply the spin modifier to an object to get it to spin.
nemisis posted Thu, 25 May 2000 at 6:31 PM
Hi Clint, No luck. Still can only rotate it 180 degrees. I tried the spin modifier, but it spins too fast, I think the lowest setting you can use is 1 rotation/sec. Any other ideas?? I tried setting 2 key frames( 1 halfway (4 sec) and one at the end (8 sec) but it just reverses the rotation at the 4 sec mark. Keithw, is there a way to sec the spin/sec to .25 rotations/sec??
keithw posted Thu, 25 May 2000 at 7:15 PM
Nemisis, I'm not sure what you mean? You can set the number of rotations per second. If you set the rotatations per second to .25 and the length of the animation to 4 seconds your planet will make one complete rotation during the 4 second animation. If the cycles per second are a positive number the planet will rotate clockwise. a negative number will rotate it counterclockwise Keith
nemisis posted Thu, 25 May 2000 at 7:17 PM
Hi Keith, Carrara will not allow me to set anything but a whole number. 1 is as low as I can go.
nemisis posted Thu, 25 May 2000 at 7:22 PM
Hi Keith & Clint, I tried to set the spin again to .25/sec and this time it worked fine, sorry guys. Thanks alot
hoborg posted Fri, 26 May 2000 at 1:06 PM
Also what you can do (for future reference) Is have the planet go 180 at the first keyframe and then at the middle keyframe set it to 0 then at the last set it to -180. That'll do it. Although Spin works too. :) Hoborg
