efitzger opened this issue on Apr 08, 2003 ยท 11 posts
efitzger posted Tue, 08 April 2003 at 7:00 PM
Attached Link: Bryce versus Vue d'Sprit
Hi, I have been a Bryce user since the first version whenever that was, and recently learned that Corel has no current plans to update this program. I really like what I have seen about Vue d'Sprit and was wondering if there are current or past users of Bryce that have switched to Vue or use both. I am interested in knowing general terms how they compare as far as ease of use, rendering time and if there is much of a learning curve going from Bryce to Vue d'Sprit. I just downloaded the demo version and hope to play with it to see how it compares. Thanks for any advice you may have. Ed FitzgeraldMightyPete posted Tue, 08 April 2003 at 7:07 PM
Click on the FAQ link, I even added a link there to a Bryce forum where this topic had already had take place. Beyond a dought this is the most frequently asked question here.
efitzger posted Tue, 08 April 2003 at 7:16 PM
Thanks I will take a look. Ed
nish posted Wed, 09 April 2003 at 1:04 AM
I've used Bryce for a while, now trasferred to Vue. As far as render time goes, I think Vue is little faster then Bryce. But, I didn't really compared it in that perspective. As far as ease of use goes, Vue is way better then Bryce. Even in options wise. I've been using Vue Demo for quite a while, posted some images also. Recently baught the full version and I have to say I'm happy with it so far. However, Vue has a little stability problem.
efitzger posted Wed, 09 April 2003 at 2:20 AM
Thanks for your response. I am glad to hear you like it. By stabiliy problems I assume you mean that it crashes occasionally.
MightyPete posted Wed, 09 April 2003 at 3:24 AM
Well I think it has to do with the operating system more than on Vue. It does not crash on me and I do a lot of work with it. Lots of work, I push it to the limits. Make sure your running 4.12. You can't judge Vue too closly with the demo the program is much better. It just gives you a taste.
TheWingedOne posted Wed, 09 April 2003 at 7:08 AM
Used Bryce for some time before switching to Vue. If you plan to use Poser figures Vue is the program of your choice. And it's render engine is a little bit faster than Bryce's. Vue is quite eays to learn, since it's GUI it's much easier to understand, but that might be only me. ;) Phil
nish posted Wed, 09 April 2003 at 1:11 PM
Umm! It actually doesn't crashes, but it used to freeze up a lot in Demo. Even on the full version it freezed up several time on me. Since, I'm a new user, I'm taking MightyPete's words in consideration. Probably soon, I'll do a fresh installation of Windows, that should stop the freezing. However, the bottom line is I prefer Vue more then Bryce.
efitzger posted Wed, 09 April 2003 at 3:15 PM
Can I ask what version of windows you are using? I have winxp home edition and, it seems fairly stable
nish posted Wed, 09 April 2003 at 8:55 PM
I have XP pro edition with the service pack. It's fairly stable too; little slow may be cuz I have so many programs installed in it. Comparing with new technology my pc is little old ... P4, 1.4Ghz & 512 RD ram. I think freezing up has lot to do with runtime environments and plug-ins. Maybe I have one or two of those, which is not suitable with Vue. Afterall you know, there are no such thing as "100% perfect". :)
Tomsde posted Fri, 11 April 2003 at 11:38 AM
An aside here, if you plan on using Poser with Vue 4 you must use Poser 4 or Poser 4 Pro Pack. Vue Poser import filter doesn't work with P5 yet, but they are supposedly working on it.
