patty39 opened this issue on Apr 09, 2003 ยท 4 posts
patty39 posted Wed, 09 April 2003 at 1:03 PM
Im new so here goes. does anyone know wher i can get some decent 3Ds Max textures for a male model. I really need hair and clothes. thanks
taerin posted Wed, 09 April 2003 at 1:37 PM
Patty - are you talking about textures you would use only in Max, not in Poser itself?
patty39 posted Wed, 09 April 2003 at 4:54 PM
If they are compatible then yes, but if not then I only want them in max.
taerin posted Wed, 09 April 2003 at 7:39 PM
Well, when I'm exporting for use in Bryce, I choose OBJ as my format. The textures that I've used in Poser are referenced in a .mtl file that gets saved in the same place as the OBJ. When I then import the file into Bryce, it knows which textures go where, and if the texture files themselves are in the same folder as the OBJ, they load in with the object. So I guess what I'm saying is that the textures you have now, or could download from Freestuff or wherever, should be able to be used in Max. Hope that helps. - taerin
