Subject: texture map dimensions
cmjackson opened this issue on Apr 12, 2003 ยท 2 posts
cmjackson posted Sat, 12 April 2003 at 7:51 AM
I just wanted some advice off someone whos good at texture maps. I may have asked this question before, so i apologize in advance if i have. When opening a UV map is it ok to just change the width or the length so your uv map isn't squished. Cos whenever i put little bits of detail onto tex maps i normally have to resize them because when rendered the details come out stretched width ways or length ways.
SamTherapy posted Sat, 12 April 2003 at 8:28 AM
Yes, you can alter the dimensions of any UV map to suit your needs. Ideally, a texture should not stretch or squash when it's mapped onto an object but there are times when it's unavoidable, such as when the tex goes around several curved areas.
