Subject: Posting Free Stuff
cruzan opened this issue on Apr 14, 2003 ยท 2 posts
cruzan posted Mon, 14 April 2003 at 5:31 PM
OK, I know somewhere on the right side panel I should find some forum about uploading; but I didn't (old eyes just aint that good). After much futzing - I finished moving my carrera music box over to P5.... Put it into my props all parented together, psuedo painted on it (thanks for those who helped btw)... here comes the big BUT - what do I include with a 3 tier prop (ie: obj, mtl needed? or just the poserprop file P5 created and jpgs bumps)? I understand that character requires the obj stuff (geometries:filename:object.obj) but not sure of prop as when I scope out pp2 file - dont find a reference to geometries:filename:box.obj just the JPGs. Sorry to bother y'awl, but this is the first time I have ever posted to the freebies - yes been member for long time and learned alot and am a very very bad girl for never posting anything free but will try to make up.... If you will just point me in the right direction ;-) Thanks for any help - pointing to where I should go - etc.
mateo_sancarlos posted Mon, 14 April 2003 at 5:41 PM
Some people say you should strip out the obj geometry lines from the pp2 file and add the geometries:filename:box.obj references as a more elegant solution, because it allows modification/replacement of the obj while retaining the same pp2 file. But either way, the upload package is the same size, whether the obj file is separate or whether it is embedded in the pp2 file.
