viper opened this issue on May 28, 2000 ยท 2 posts
viper posted Sun, 28 May 2000 at 1:33 PM
I have ton of morphs that I made in poser with the magnets and Iwant to post them to the free stuff but when I export them form poser they are not working I select the box to export them as morhp targets. If someone can help me out please
bloodsong posted Sun, 28 May 2000 at 6:28 PM
heya; you need to apply the magnet, then select the body part and 'spawn morph target.' then you need to set each morph target to 1 in turn and export the body part to an obj. make sure the figure is zeroed and is also at 0,0,0 coordinates. do NOT select 'export as morph target.' that will turn off all morphs as well as zero the figure. (i think they meant that to say 'export as morph base.') grab bushi's morph squeeze utility to strip the obj's; zip them up and post them. alternately, you could post the cr2 with the morphs in it.
