Subject: Feet stuck to the ground in Poser 4? Help!
TheHookUp opened this issue on Apr 18, 2003 ยท 4 posts
TheHookUp posted Fri, 18 April 2003 at 12:22 PM
Hi, there. I'm new to Poser. Just got Poser 4 really cheap in a software store. Didn't have the money for Poser 5. When I open a model in Poser and I select the thigh and then use the Bend dial, instead of the leg coming up, the thigh just rotates and messes up. What gives? Are the feet stuck to the ground or what? What can I do?
dialyn posted Fri, 18 April 2003 at 12:26 PM
Attached Link: http://www.fallencity.net/lore/p-h-start1.php
You need to uncheck Inverse Kinectics for the legs. Look at the example on this link. Poser 4 and Poser 5 work the same in this case. Hope that helps.
TheHookUp posted Fri, 18 April 2003 at 12:28 PM
Oh, that was easy! Thanks a lot, dialyn. Appreciate the quick reply.
dialyn posted Fri, 18 April 2003 at 12:29 PM
You're welcome. :)
