Subject: Newbie needs help.......Please
Speedbump opened this issue on Apr 20, 2003 ยท 14 posts
Speedbump posted Sun, 20 April 2003 at 12:37 AM
I am kinda new to poser 4 and am doing my own textures now...One problem I am having though is the eyebrows that I put in the texture don't show up.They are under the default poser ones and also the nipples are there along with the ones I put in the texture..What can I do to get rid of these default pieces?
tasquah posted Sun, 20 April 2003 at 12:39 AM
Speed , What model are your trying to texture ?
Speedbump posted Sun, 20 April 2003 at 12:41 AM
the default female nudeP4.....everything else works fine. Eyelashes, pubic hair, etc.Its just those pesky plastic looking eyebrows and nipples.
tasquah posted Sun, 20 April 2003 at 12:57 AM
How about a sample render ?
Speedbump posted Sun, 20 April 2003 at 1:16 AM
here is a quickie I just did for the purpose of you seeing what I mean...
EricofSD posted Sun, 20 April 2003 at 1:34 AM
ah, er, well, um.... There is a 'brows gone' dial that you can play with. Seems that some of the models, mil models in particular, have a separate mesh that the eyebrows go on. Either set your eyebrows to that mesh, or ditch it with the dial and use the normal headskin.
lindans posted Sun, 20 April 2003 at 1:57 AM
I had this problem and find that turning the dials for "brows in"up to around 5.000 seems to get rid of it, I am kind of new to so don't take my word for it but give it a try.
Oh, let the sun beat down upon my face. I am a traveler of both time and space ....Kashmir, Led Zeppelin
Speedbump posted Sun, 20 April 2003 at 1:57 AM
where might this "brows gone" dial be?
EricofSD posted Sun, 20 April 2003 at 2:54 AM
Ok, sorry, didn't read carefully enough. There's no brows gone dial on posette.
One thought though... see if you have any of your textures checked to apply to the entire figure. If so, that might override your eyebrows texture.
If you made your eyebrows as a part of the regular p4 woman texture, then ok, but if you made them separate, then check the eyebrows as in this image and don't check the applies to entire figure box for any of your other textures.
er, um, hope this helps.
Speedbump posted Sun, 20 April 2003 at 3:08 AM
Thanks for the help
raven posted Sun, 20 April 2003 at 9:53 AM
You could also try changing the object colour of the eyebrows to the same object colour as the skin. The colour is what you are seeing over the texture.
Speedbump posted Sun, 20 April 2003 at 11:55 AM
Thanks for all the help...I think I got it....tweaking the surface materials a bit is what you need to do I guess....
queri posted Sun, 20 April 2003 at 2:46 PM
Attached Link: http://www.morphworld30.com/files.html
That's a very beautiful texture-- yeah-- try it over an all white Posette. I think Traveller's Hide Show MATS have one for her. Down at the bottom of the page [use link]utility poses. Emily
queri posted Sun, 20 April 2003 at 2:47 PM
Um, there are also some morphs in FS to smooth the mesh. Emily
