ilr opened this issue on Apr 22, 2003 ยท 5 posts
ilr posted Tue, 22 April 2003 at 12:41 AM
I didn't really understand how tailor works from the description i found at daz site. 1. can i use any clothing item initially designed for v3 (let's say - i download a dress from poserworld site that has no morphs at all and fits only default v3 body shape) and use this clothing item on a modified v3 figure (let's say i get pandora character from our market place)? 2. or I need to use only those clothing items that have exactly the same morphs that V3 body pack? 3. does it work properly with v3? 4. does it work properly with V3 and Glamorous Resort collection for V3 by Jim Burton "properly" means clothing items have all necessary body morphs. thank you in advance
RHaseltine posted Tue, 22 April 2003 at 6:05 AM
You load the figure (for V3 you need to inject the morphs you want in Poser and save a CR2 - if you have Poser5 you also need to perform some surgery on the CR2 file to remove stuff that Tailor doesn't understand, P4 and ProPack work OK). You load the conforming clothing item. You tick one or more figure morphs you wish to transfer to the clothing. Tailor thinks for a bit, and adds a morph. You save the clothing. If it had no "Hip" you will need to fiddle a bit to avoid having the item floating at halo height - simplest is to use MorphManager to transfer your new morph to a copy of the original item, but you can also hand edit the CR2 or just load the original into Poser then double click the new version to replace it. For custom figures. If it's a dialed up figure you can spawn a new morph target for the V3 and Tailor to that, or you can Tailor each of the morphs you used and then set them to the same values as the figure's in Poser - it depends on whther you want flexibility or simplicity. If it's a morph made with magnets or in a modelling application, as long as you've spawned it as a V3 morph target it will work like any other morph. One thing to be aware of is that Tailor often does poorly with "shrinking" morphs (BreastSizes<4 say).
shogakusha posted Tue, 22 April 2003 at 11:52 AM
Not that I want to steal CodeTwister's thunder, but I just received an email from him indicating an updated Tailor was on the way in a few weeks, including support for Poser 5 and V3!
RHaseltine posted Tue, 22 April 2003 at 1:01 PM
(Hooray yippee woohoo)^3
ilr posted Tue, 22 April 2003 at 11:57 PM
thank you rHaseltine
