MaxBeckett opened this issue on Apr 23, 2003 ยท 8 posts
MaxBeckett posted Wed, 23 April 2003 at 7:29 AM
sfdex posted Wed, 23 April 2003 at 11:26 AM
My guess -- and it's only a guess -- is that the size of the bulb light you've placed inside the lamp is larger than the lamp shade, so we're seeing the light hit the wall partially unobscured by the lampshade. Try reducing the scale of the bulb light and see if that helps....
pixelicious posted Wed, 23 April 2003 at 1:50 PM
I thought it said in the Carrara manual that the size/scale of lights and cameras is irrelevant in the 3D environment. If you're using a point light, the light should eminate from a single point, i'm guessing the center of the the light. I may be wrong, because I'm also guessing, but I don't thing changing the scale will affect this any. -Scott
Kixum posted Wed, 23 April 2003 at 2:27 PM
If you're using C2.0, make absolutely sure you patch it. There is a bug in C2.0 with soft shadows the patch addresses. If this doesn't fix it or you've already patched, let us know. Nice scene! -Kix
-Kix
MaxBeckett posted Thu, 24 April 2003 at 7:52 AM
Kixum posted Thu, 24 April 2003 at 11:50 AM
Well if the shade isn't casting a shadow, I'd say something else next to the bulb is. -Kix
-Kix
sfdex posted Thu, 24 April 2003 at 11:53 AM
Hmm.... I'm stumped. Next time I'm playing with Carrara I'll have to see if I can duplicate the problem. In the meantime, could you turn the shade itself into an anything glows object and just delete the point light? Just a thought as a workaround.
pem posted Sun, 11 May 2003 at 12:50 AM
How is your lampshade constructed? The shadow pattern looks like intersecting polygons. Two thoughts come to mind: is your object double-sided and are all your normals pointing the same way? How are you making the lampshade glow? Is it an anything glows light? In which case, maybe you need to change the standoff and minimum distance. I haven't seen Kixum's tutorial so I don't know how you built the scene.
