Subject: trans map help?
RICHARD opened this issue on Apr 23, 2003 ยท 6 posts
RICHARD posted Wed, 23 April 2003 at 7:43 PM
is it possible to make part of a texture transparent?if so how?please need help me some.thanks
pdxjims posted Wed, 23 April 2003 at 8:51 PM
You do this by creating a transmap texture. A transmap texture is done in shades of grey, black, and white. White colored areas are completely opaque, black is completely invisible, grey is semi transparent, depending on the darkness of the grey shade. So, to make one part transparent, create a transmap from the orginal texture, paint the part you want transparent black, and the rest white. Save it under a different name (usually the same as the texture with "trnas" added to the name. Then go into materials and assign the new transmap to the transparency node, set the transparency value to max, and render. There's a good tutorial on transmaps here somewhere, and the poser manual explains it pretty well. Transmaps are used for eyebrows, eyelashes, and pubic hair on body and head textures too. You can have a lot of fun making different transmaps. I usually use them to create a mesh or webbed look to a piece of clothing. Hope this helps.
RICHARD posted Wed, 23 April 2003 at 10:39 PM
thanks for the input,will it be the same in poser4?
TrekkieGrrrl posted Thu, 24 April 2003 at 12:49 AM
Yep. Same applies to Poser 4 :o)
mindycen posted Thu, 24 April 2003 at 10:40 AM
Attached Link: http://www.fallencity.net/
a good tutorial on how to do trans in P4 is at the site.
RICHARD posted Thu, 24 April 2003 at 11:39 AM
thanks for all your input.tried an works fine.now for some serious transmap making.
