keithw opened this issue on May 31, 2000 ยท 1 posts
keithw posted Wed, 31 May 2000 at 7:00 AM
I found a way to name polymeshes using the Cut and Paste functions. First Select and Detach the polygons you want to name. Then use the Cut function to remove the selected polygons. Select the remaining polygons. This will allow you to name the polygons in the Polymesh Name field in the property tray. Then use the Paste function to replace the cut polygons. They are placed back in their original position. Then name them in the using the Polymesh Name field in the property tray. Has anyone figured out how to use the replicate in a circle yet? Keith
